Journal Record of NX Open
Dear master,
I'm Sun,the Enginner of EF Elcetrical(Shenzhen)Co.,Ltd.
I want to customize some commands use NX Open,For example,use Marco Record,Journal Record.
I have successed to customize some commands use Marco Record,but Marco files can't change to similar command Marco files,
So I want to use Journal Record,but face difficulty.Could I ask you or your Enginner some questions and reply me use E-mail zs.zhang@eugster.cn
Best regards
Sun Zhang(张中山)
Re: Journal Record of NX Open
Siemens Genius Siemens Genius
Siemens Genius
Hi Sun
I will be happy to answer your questions about Journal / NXOpen program.
you can ask them here in this Forum.
It's one of the goal of this forum , share experience and knowledge around the NX community
Best Regards
Is there any tutorial for NX Open?  I paid for a personal tutorial for teamcenter.    Thanks.
Siemens Genius
Hi Omvegan
NX Open is a brunch of many different languages,technologies on different platforms
If you start to develop automation and program in NX, my advice is to start learning SNAP.
S.N.A.P stands for Simple NX Application Programming. It's based on .NET programming so Windows Only.
Your can access to the SNAP tutorial in the NX DOC.
Goto the Programming  Chapter / ==> To view the Programming Tools help click here
then SNAP / SNAP getting Started Guide.
There is also many SNAP Examples in your D:\softs\NX9\UGOPEN\SNAP\Examples
I believe that this would be a good start to learn. After your can go one step higher with NXOPEN , which is the same , but much powerful, rich , so more complex to program.
There are also many NX OPEN Example in your D:\softs\NX9\UGOPEN\SampleNXOpenApplications in 4 different languages (VB, C#, C++ and Java)
Good Luck / Welcome on the NX OPEN user group and let us know your progress.
