cancel
Journal not working correctly with Office365
I am having an issue with a journal that we use to export a view to a word document, this used to work until we upgraded to Office365, I was wondering if anyone has come across this issue before?
Below is the code we are currently using this is a .VB code:
Sub Main()
CopyDisplay()
Dim wrd = CreateObject("Word.Application")
wrd.Documents.Open("\\teams\csd\qga\Procedures\PE551-01.doc",,True)
'wrd.Documents.Open("\\renport\QA\Procedures\PE551-01.doc",,True)
wrd.Visible = True
wrd.Selection.Paste
Any help on this is greatly appreciated.
Dave
NX10.0.3MP13
NX11.0.1
Production
TC10
Vericut 7.3,7.4.1,8.0.2
Re: Journal not working correctly with Office365
Hello Dave
I had the exact same problem, and it was becauce the office documents were opening by default in the viewing mode, instead of the editing mode.
This setting can be changed in the options.
Martyn, Snr CAE Engineer, Renishaw PLC
NX10 Tc10
Hi Martyn,
Luckily one of our guy's found this out and we are working towards a fix.
Dave
NX10.0.3MP13
NX11.0.1
Production
TC10
