Link Part Attribtue
1) Open your desired template file - for an example Drawing_B-Size-template.prt
2) File > Utilities > Attribute Templates
Title: DB_DWG_TEMPLATE_DESCRIPTION
OK
3) Start > Drafting
4) Insert > Annotation > Note
Symbols > Category: Relationships > Insert Part Attribute
Expand [+] Unset and select DB_DWG_TEMPLATE_DESCRIPTION
OK
Place the note on the drawing sheet.
5)Insert > Table > Tabular Note
Edit any of the tabular note cell by Edit Text
OK
FIle > Save
File > Close > All Parts
6) Create a new model part
7) File > Properties > Attributes
Title: DESCRIPTION
Value: This is a test
OK
8) File > New > Drawing (tab) > B - Size > OK
9) Note placed in the Drawing file displays the value from step 7 but tabular note cell does not do.Why?
Re: Link Part Attribtue
I followed your instructions and both notes updated for me, NX 9.0.3.
What version of NX are you using?
I am using NX 8.5.0
