Load options
In our company we use NX with the Rob Cohon customization . we need to have the load options for each user .How can I do it?
thank you for your help
NX 9
Re: Load options
Esteemed Contributor
Does each user have his individual load options or are you able to separate them into groups?
#  This variable defines the ascii file that contains the load options settings.
#  If it is not set, a file called load_options.def in the current directory
#  is searched for instead.  NOTE: If you set this to a file specification
#  that contains spaces, you must enclose the file in quotes, e.g
#  UGII_LOAD_OPTIONS="c:\my Data Files\load_options.def"
The above is the default definition for ugii_env.dat
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.7 | TcUA 10.1 MP7 Patch 0 ( | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
