Loading of NX DLL's failed
Hi All,
PFB the image, where my NX DLL's are not loading properly. I am adding references from NXBIN managed. But i dont know why this is happening. This issue is not affecting my applications working. But wanted to know why is this happening.
Betreff: Loading of NX DLL's failed
I do not see any error. The first line tells you that the required .net assembly ist not present now. The second line tells you that it has been successfully loaded. So it is present now. Everything looks fine.
Jan
Jan Böttcher
Thank you for the reply,
I thought failing and loading is some kind of issue.
Thanks for clearing my doubt
