Mac os NX8.5 not able to connect with network license server
Having issues with a new install of NX8.5 on a Mac os nat able to see the license server on the network.  I am able to ping the license server but the MAc machine will not find it.  Any Ideas?
Re: Mac os NX8.5 not able to connect with network license server
Esteemed Contributor
Have you checked with telnet if you can connect to the server using the port 28000?
How is your UGS_LICENSE_SERVER environment variable set?
Yes on both, double checked and tripple checked.
Even added the IP to the host file so I could use the workstation name.
And silll get the error -96 can't connect to license server.
Last try: Is NX added as an exception to the firewall?
That was it, I was helping someone get this going, they had turned off thier filter but it must have changed something in the system.  They uninstalled the network filter and it started working.
I hate long distance support, and not completely knowing the operating system.  Lukily I know some unix so that helped.
Thanks for your help!!
