Making table with the Block Styler
Hello everyone!
How can I use Block Styler to create a custom menu with the table like this one?
Re: Making table with the Block Styler
look this way :
...\UGOPEN\SampleNXOpenApplications\C++\BlockStyler\EditExpression\EditExpression.dlx
@mkn
Production: NX11.0.2.7,VERICUT 7.3.3
Development: Tcl/Tk, Gnuplot
www.deshors-tiremold.com
Esteemed Contributor
The widget similar to a spreadsheet is a tree list, see the NXOpen API reference for more information.
Hmm, in the descirption is goes like this: "The Tree List block creates a tree-node structure representing a node hierarchy". Is it really for the spreadsheet-like appearance?
You can make it have a spreadsheet like appearance. From the TreeList documentation:
The combination of tree properties and node insertion mechanism allows the tree to behave like a table.
This can be achieved by setting the ShowExpandCollapseMarker property on the tree to False and inserting a node whose parent node is null.
Production: NX8.5.3.3 MP11 64bit Testing: NX9.0.2.5
The images below use both a tree list one without and one with a node hierarchy.
Tree without Node HierarchyTree without Node Hierarchy
Tree with Node HierarchyTree with Node Hierarchy
With icons and menus:
Save ManagerSave Manager
Attila Szepesi, Application Engineer, graphIT Ltd.
Production: NX11.0.2 | TcUA 11.2 MP2 Patch 1 (11.2.2.1)
Development: VB.NET Testing: NX12.0
Thank you all! I will have a look at this.
Do I get it right that the tree list can only be filled during runtime? Or can I prepare the list in advance in the Block Styler?
You must fill it at runtime, there is no way to prepare it.
