Material removal rate in journal
Hi everyone,
I want to export the material removal rate to a file in excel. I found this thread that talks about the mrr : https://community.plm.automation.siemens.com/t5/Discussion-Forum-NX-Manufacturing/Metal-removal-rate...
My problem is that i don't know where I have to write these lines :
# Save material removal rate to file
# UGII_CAM_WRITE_MRR="d:\users\rief\nx10\mrr.csv"
 The second question that I have is how do I use it with the journal ?
I would like to have a journal that change an operation (to use the Optimize feed rate command), generate the mrr data (by generating the tool path ?) to store it and undo the changes.
Can you help me ?
