Mirroring a point
Innovator
Innovator
How would you mirror a point from a selected plane?
Re: Mirroring a point
Honored Contributor
Honored Contributor
Have you recorded a journal of the operation? The recorded code will give you most of what you need.
If you want to modify the recorded code to allow the user to select the plane, try searching the GTAC solution center for "select plane" or "select datum plane".
http://solutions.industrysoftware.automation.siemens.com/view.php?si=nx_api2937
This is pretty easy to do from first principles
Dim q As Position    ' Point on plane
Dim n As Vector      ' Unit vector normal to plane
Dim p As Position    ' The point we want to mirror
Dim mirroredPoint As Position = p - 2*((p-q)*n)*n
The * operation is a vector dot product, where appropriate.
山田
yamada
