Move Csys C# NXOpen
Hi Guys,
i want replace the Origin of an Csys by a new Point 3D.
In other word.. i want to Move the Csys to a new Position.
Has anybody an idea how to do that in C# ?
Thanks a lot !
Re: Move Csys C# NXOpen
Esteemed Contributor
See the CoordinateSystem.Origin property to get or set the origin of a coordinate system.
thanks for you answer.
I tried it with the set property of Origin but NX dont move the Datum. It seems like it added another origin to the Datum :/
You didn't say that this is a datum coordinate system.
Have you already tried to record a journal of the manual process, which is what I always do, if I don't really know how a thing is done programmatic.
So now i used the xforms
xform1 = workPart.Xforms.CreateXform(New_Origin, X_Direction, Y_Direction, NXOpen.SmartObject.UpdateOption.WithinModeling, 1.0);
My Problem now is that with the xform i m creating a new Coordinate System and all my Parents gets lost ?
Is there a possibility to add an xform to an existing Coordinatesystem or to replace the xform of an Coordinatesystem ?
the Journal recommends me this function :
xform1 = workPart.Xforms.CreateXformByDynamicOffset(cartesianCoordinateSystem1, originOffset1, trasformMatrix1, NXOpen.SmartObject.UpdateOption.WithinModeling, 1.0);
but i don't really understand how to use the originOffset and the transformMatrix ? :/
Both are specified above their usage, so you need to take a look at their place of definition.
Are you moving the datum or changing the origin by editing the datum?
For me it looks like you are moving the datum, you may want to also record a journal for editing the datums origin through the datums properties, which seems to be a much easier code to handle.
could you tell me how i can change the origin trough the Datums properties in NX ?
Edit the feature?
Hi IIdon,
You could try this in this way.  I made a function for moving the component and then calling the same in main function by the name of the component and by the point I want.
Here is the code:
using System;
using System.Collections;
using System.Collections.Generic;
using System.Data;
using System.Diagnostics;
using NXOpen;
using NXOpen.assemblies;
static class MyClass
public static void Main(string[] args)
Session theSession = Session.GetSession();
Part workPart = theSession.Parts.Work;
Part displayPart = theSession.Parts.Display;
//your component
component a = (Assemblies.Component)workPart.ComponentAssembly.RootComponent.FindObject("YOUR COMPONENT");
//Your point
point3d b = new Point3d(10.0, 217.567763205195, -213.758947434623);
//One line function
Move_My_Component(ref a, ref b);
public static object Move_My_Component(ref component a, ref point3d b)
// Menu: Assemblies->Component Position->Move Component...
Session.UndoMarkId markId1 = default(Session.UndoMarkId);
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start");
Positioning.ComponentPositioner componentPositioner1 = default(Positioning.ComponentPositioner);
componentPositioner1 = workPart.ComponentAssembly.Positioner;
componentPositioner1.ClearNetwork();
Assemblies.Arrangement arrangement1 = (Assemblies.Arrangement)workPart.ComponentAssembly.Arrangements.FindObject("Arrangement 1");
componentPositioner1.PrimaryArrangement = arrangement1;
componentPositioner1.BeginMoveComponent();
bool allowInterpartPositioning1 = false;
allowInterpartPositioning1 = theSession.Preferences.Assemblies.InterpartPositioning;
Positioning.Network network1 = default(Positioning.Network);
network1 = componentPositioner1.EstablishNetwork();
Positioning.ComponentNetwork componentNetwork1 = (Positioning.ComponentNetwork)network1;
componentNetwork1.MoveObjectsState = true;
Assemblies.Component nullAssemblies_Component = null;
componentNetwork1.DisplayComponent = nullAssemblies_Component;
componentNetwork1.NetworkArrangementsMode = Positioning.ComponentNetwork.ArrangementsMode.Existing;
componentNetwork1.RemoveAllConstraints();
NXObject[] movableObjects1 = new NXObject[-1 + 1];
componentNetwork1.SetMovingGroup(movableObjects1);
componentNetwork1.Solve();
Session.UndoMarkId markId2 = default(Session.UndoMarkId);
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Move Component Update");
NXObject[] movableObjects2 = new NXObject[1];
Assemblies.Component component1 = a;
movableObjects2(0) = component1;
componentNetwork1.SetMovingGroup(movableObjects2);
Features.DatumCsys datumCsys1 = (Features.DatumCsys)workPart.Features.FindObject("DATUM_CSYS(1)");
CartesianCoordinateSystem cartesianCoordinateSystem1 = (CartesianCoordinateSystem)datumCsys1.FindObject("CSYSTEM 1");
Xform xform1 = default(Xform);
xform1 = workPart.Xforms.CreateXform(cartesianCoordinateSystem1, SmartObject.UpdateOption.AfterModeling);
CartesianCoordinateSystem cartesianCoordinateSystem2 = default(CartesianCoordinateSystem);
cartesianCoordinateSystem2 = workPart.CoordinateSystems.CreateCoordinateSystem(xform1, SmartObject.UpdateOption.AfterModeling);
int nErrs1 = 0;
nErrs1 = theSession.UpdateManager.AddToDeleteList(componentNetwork1);
int nErrs2 = 0;
nErrs2 = theSession.UpdateManager.DoUpdate(markId2);
Session.UndoMarkId markId3 = default(Session.UndoMarkId);
markId3 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Start");
Unit unit1 = (Unit)workPart.UnitCollection.FindObject("MilliMeter");
// Dialog Begin CSYS
Session.UndoMarkId markId4 = default(Session.UndoMarkId);
markId4 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "CSYS");
theSession.DeleteUndoMark(markId4, null);
Session.UndoMarkId markId5 = default(Session.UndoMarkId);
markId5 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "CSYS");
Point3d origin1 = b;
// New Point3d(10.0, 217.567763205195, -213.758947434623)
Vector3d xDirection1 = new Vector3d(1.0, 0.0, 0.0);
Vector3d yDirection1 = new Vector3d(0.0, 1.0, 0.0);
Xform xform2 = default(Xform);
xform2 = workPart.Xforms.CreateXform(origin1, xDirection1, yDirection1, SmartObject.UpdateOption.AfterModeling, 1.0);
CartesianCoordinateSystem cartesianCoordinateSystem3 = default(CartesianCoordinateSystem);
cartesianCoordinateSystem3 = workPart.CoordinateSystems.CreateCoordinateSystem(xform2, SmartObject.UpdateOption.AfterModeling);
Positioning.Network network2 = default(Positioning.Network);
network2 = componentPositioner1.EstablishNetwork();
Positioning.ComponentNetwork componentNetwork2 = (Positioning.ComponentNetwork)network2;
componentNetwork2.MoveObjectsState = true;
componentNetwork2.DisplayComponent = nullAssemblies_Component;
componentNetwork2.NetworkArrangementsMode = Positioning.ComponentNetwork.ArrangementsMode.Existing;
componentNetwork2.RemoveAllConstraints();
NXObject[] movableObjects3 = new NXObject[1];
movableObjects3(0) = component1;
componentNetwork2.SetMovingGroup(movableObjects3);
componentNetwork2.Solve();
Session.UndoMarkId markId6 = default(Session.UndoMarkId);
markId6 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "CSYS to CSYS");
bool loaded1 = false;
loaded1 = componentNetwork2.IsReferencedGeometryLoaded();
componentNetwork2.BeginDrag();
Vector3d translation1 = new Vector3d(b.x, b.y, b.z);
Matrix3x3 rotation1 = default(Matrix3x3);
rotation1.Xx = 1.0;
rotation1.Xy = 0.0;
rotation1.Xz = 0.0;
rotation1.Yx = 0.0;
rotation1.Yy = 1.0;
rotation1.Yz = 0.0;
rotation1.Zx = 0.0;
rotation1.Zy = 0.0;
rotation1.Zz = 1.0;
componentNetwork2.DragByTransform(translation1, rotation1);
componentNetwork2.EndDrag();
componentNetwork2.ResetDisplay();
componentNetwork2.ApplyToModel();
int nErrs3 = 0;
nErrs3 = theSession.UpdateManager.AddToDeleteList(componentNetwork2);
int nErrs4 = 0;
nErrs4 = theSession.UpdateManager.DoUpdate(markId2);
Positioning.Network network3 = default(Positioning.Network);
network3 = componentPositioner1.EstablishNetwork();
Positioning.ComponentNetwork componentNetwork3 = (Positioning.ComponentNetwork)network3;
componentNetwork3.MoveObjectsState = true;
componentNetwork3.DisplayComponent = nullAssemblies_Component;
componentNetwork3.NetworkArrangementsMode = Positioning.ComponentNetwork.ArrangementsMode.Existing;
componentNetwork3.RemoveAllConstraints();
NXObject[] movableObjects4 = new NXObject[1];
movableObjects4(0) = component1;
componentNetwork3.SetMovingGroup(movableObjects4);
componentNetwork3.Solve();
int nErrs5 = 0;
nErrs5 = theSession.UpdateManager.AddToDeleteList(componentNetwork3);
int nErrs6 = 0;
nErrs6 = theSession.UpdateManager.DoUpdate(markId2);
componentPositioner1.DeleteNonPersistentConstraints();
int nErrs7 = 0;
nErrs7 = theSession.UpdateManager.DoUpdate(markId2);
componentPositioner1.EndMoveComponent();
Assemblies.Arrangement nullAssemblies_Arrangement = null;
componentPositioner1.PrimaryArrangement = nullAssemblies_Arrangement;
regards,
Abhi
