Do you mean
Reply
Move component to its absolute CSYS
Hi
what would the code for moving a part/Component to any CSYS?
Just one line code i need such as for moving/transformation it would be
workPart.ComponentAssembly.MoveComponent(selComp, pt3, RotMat3)
So if enter my X,Y,Z values it should transfer it that CSYS.
Re: Move component to its absolute CSYS
Hello Dinesh,
I don't think you can get such api directly because there many parameters to control it.
But a better way would be creating a funtion of it and call it as you want as "One line".
This you could try:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.assemblies
Module NXJournal
Sub Main (ByVal args() As String)
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
'your component
dim a as component= CType(workPart.ComponentAssembly.RootComponent.FindObject("YOUR COMPONENT"), Assemblies.Component)
'Your point
dim b as point3d= New Point3d(10.0, 217.567763205195, -213.758947434623)
'One line function
Move_My_Component(a, b)
End Sub
Public Function Move_My_Component(Byref a as component,byref b as point3d)
' Menu: Assemblies->Component Position->Move Component...
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")
Dim componentPositioner1 As Positioning.ComponentPositioner
componentPositioner1 = workPart.ComponentAssembly.Positioner
componentPositioner1.ClearNetwork()
Dim arrangement1 As Assemblies.Arrangement = CType(workPart.ComponentAssembly.Arrangements.FindObject("Arrangement 1"), Assemblies.Arrangement)
componentPositioner1.PrimaryArrangement = arrangement1
componentPositioner1.BeginMoveComponent()
Dim allowInterpartPositioning1 As Boolean
allowInterpartPositioning1 = theSession.Preferences.Assemblies.InterpartPositioning
Dim network1 As Positioning.Network
network1 = componentPositioner1.EstablishNetwork()
Dim componentNetwork1 As Positioning.ComponentNetwork = CType(network1, Positioning.ComponentNetwork)
componentNetwork1.MoveObjectsState = True
Dim nullAssemblies_Component As Assemblies.Component = Nothing
componentNetwork1.DisplayComponent = nullAssemblies_Component
componentNetwork1.NetworkArrangementsMode = Positioning.ComponentNetwork.ArrangementsMode.Existing
componentNetwork1.RemoveAllConstraints()
Dim movableObjects1(-1) As NXObject
componentNetwork1.SetMovingGroup(movableObjects1)
componentNetwork1.Solve()
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Move Component Update")
Dim movableObjects2(0) As NXObject
Dim component1 As Assemblies.Component=a
movableObjects2(0) = component1
componentNetwork1.SetMovingGroup(movableObjects2)
Dim datumCsys1 As Features.DatumCsys = CType(workPart.Features.FindObject("DATUM_CSYS(1)"), Features.DatumCsys)
Dim cartesianCoordinateSystem1 As CartesianCoordinateSystem = CType(datumCsys1.FindObject("CSYSTEM 1"), CartesianCoordinateSystem)
Dim xform1 As Xform
xform1 = workPart.Xforms.CreateXform(cartesianCoordinateSystem1, SmartObject.UpdateOption.AfterModeling)
Dim cartesianCoordinateSystem2 As CartesianCoordinateSystem
cartesianCoordinateSystem2 = workPart.CoordinateSystems.CreateCoordinateSystem(xform1, SmartObject.UpdateOption.AfterModeling)
Dim nErrs1 As Integer
nErrs1 = theSession.UpdateManager.AddToDeleteList(componentNetwork1)
Dim nErrs2 As Integer
nErrs2 = theSession.UpdateManager.DoUpdate(markId2)
Dim markId3 As Session.UndoMarkId
markId3 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Start")
Dim unit1 As Unit = CType(workPart.UnitCollection.FindObject("MilliMeter"), Unit)
' Dialog Begin CSYS
Dim markId4 As Session.UndoMarkId
markId4 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "CSYS")
theSession.DeleteUndoMark(markId4, Nothing)
Dim markId5 As Session.UndoMarkId
markId5 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "CSYS")
Dim origin1 As Point3d =b
' New Point3d(10.0, 217.567763205195, -213.758947434623)
Dim xDirection1 As Vector3d = New Vector3d(1.0, 0.0, 0.0)
Dim yDirection1 As Vector3d = New Vector3d(0.0, 1.0, 0.0)
Dim xform2 As Xform
xform2 = workPart.Xforms.CreateXform(origin1, xDirection1, yDirection1, SmartObject.UpdateOption.AfterModeling, 1.0)
Dim cartesianCoordinateSystem3 As CartesianCoordinateSystem
cartesianCoordinateSystem3 = workPart.CoordinateSystems.CreateCoordinateSystem(xform2, SmartObject.UpdateOption.AfterModeling)
Dim network2 As Positioning.Network
network2 = componentPositioner1.EstablishNetwork()
Dim componentNetwork2 As Positioning.ComponentNetwork = CType(network2, Positioning.ComponentNetwork)
componentNetwork2.MoveObjectsState = True
componentNetwork2.DisplayComponent = nullAssemblies_Component
componentNetwork2.NetworkArrangementsMode = Positioning.ComponentNetwork.ArrangementsMode.Existing
componentNetwork2.RemoveAllConstraints()
Dim movableObjects3(0) As NXObject
movableObjects3(0) = component1
componentNetwork2.SetMovingGroup(movableObjects3)
componentNetwork2.Solve()
Dim markId6 As Session.UndoMarkId
markId6 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "CSYS to CSYS")
Dim loaded1 As Boolean
loaded1 = componentNetwork2.IsReferencedGeometryLoaded()
componentNetwork2.BeginDrag()
Dim translation1 As Vector3d = New Vector3d(b.x,b.y ,b.z)
Dim rotation1 As Matrix3x3
rotation1.Xx = 1.0
rotation1.Xy = 0.0
rotation1.Xz = 0.0
rotation1.Yx = 0.0
rotation1.Yy = 1.0
rotation1.Yz = 0.0
rotation1.Zx = 0.0
rotation1.Zy = 0.0
rotation1.Zz = 1.0
componentNetwork2.DragByTransform(translation1, rotation1)
componentNetwork2.EndDrag()
componentNetwork2.ResetDisplay()
componentNetwork2.ApplyToModel()
Dim nErrs3 As Integer
nErrs3 = theSession.UpdateManager.AddToDeleteList(componentNetwork2)
Dim nErrs4 As Integer
nErrs4 = theSession.UpdateManager.DoUpdate(markId2)
Dim network3 As Positioning.Network
network3 = componentPositioner1.EstablishNetwork()
Dim componentNetwork3 As Positioning.ComponentNetwork = CType(network3, Positioning.ComponentNetwork)
componentNetwork3.MoveObjectsState = True
componentNetwork3.DisplayComponent = nullAssemblies_Component
componentNetwork3.NetworkArrangementsMode = Positioning.ComponentNetwork.ArrangementsMode.Existing
componentNetwork3.RemoveAllConstraints()
Dim movableObjects4(0) As NXObject
movableObjects4(0) = component1
componentNetwork3.SetMovingGroup(movableObjects4)
componentNetwork3.Solve()
Dim nErrs5 As Integer
nErrs5 = theSession.UpdateManager.AddToDeleteList(componentNetwork3)
Dim nErrs6 As Integer
nErrs6 = theSession.UpdateManager.DoUpdate(markId2)
componentPositioner1.DeleteNonPersistentConstraints()
Dim nErrs7 As Integer
nErrs7 = theSession.UpdateManager.DoUpdate(markId2)
componentPositioner1.EndMoveComponent()
Dim nullAssemblies_Arrangement As Assemblies.Arrangement = Nothing
componentPositioner1.PrimaryArrangement = nullAssemblies_Arrangement
End function
End Module
Hi
Thanks for you reply.
I already have my code written and works well with transformation.Say i wanted to move my component it translates it in X,Y,Z directions by the value i feed as input.
But i am not interested in that.I dont like it to be translated but i want it to be placed as X,Y,Z CSYS.
When i input X,Y,Z they are not the translation values they are its CSYS.
Clear
If this line could be modified such as
workPart.ComponentAssembly.MoveComponent(selobjs,pt3, RotMat3)
the above line has to modified to
workPart.ComponentAssembly.DragByTransform(pt3, RotMat3)
But it is not working
That is my problem.
I got your point.
But if API is not available, you can't get as you want.
Only option to create a function of it.
I request other users to comment on it.
Abhi
I wonder these community members (Siemens Fellow) are not even able to help me out.
I have tried all the possible ways of contacting them.
That's what worries me a lot.
Hello Dinesh,
Community members won't expect comments like this.
There are people with lot of experience in customization. You can not disrespect them like this.
All you have to do is be patient and wait for proper solution.
If I am not able to solve things, other experinced people will also come out with proper solution. it may take time a bit.
So why so hurry!
Abhi
Sorry if i am rude and i haven't said anything like that.
I am helpless because i am trying for this solution for long time.
Anyway thanks for your valuabe reply.
