NX 10 interactive class editor: Java virtual machine error
Hello everyone,
I have NX10 and when i hit the IDE button for Knowledge Fusion, Nx throws an error message "Could not locate Java Virtual Machine Library"
I tried setting up my environment variables :
UGII_JVM_LIBRARY_DIR  = C:\Program Files (x86)\Java\jre1.8.0_77\bin\client
UGII_JAVA_HOME = C:\Program Files (x86)\Java\jre1.8.0_77
I am still getting the same error. (see attached image for the complete error message)
Please let me know if you have any suggestions!
Re: NX 10 interactive class editor: Java virtual machine error
I believe that you will need the 64 bit version of Java installed.
Yes! That solved the issue. It is so strange that you need to go and pick x64 version for Java. By default, the update installs 32 bit version.
I need to change my environment variables too:
UGII_JAVA_HOME = C:\Program Files\Java\jre1.8.0_77
UGII_JVM_LIBRARY_DIR = C:\Program Files\Java\jre1.8.0_77\bin\server
