Do you mean
Reply
NX API matching the JtkProperty API ?
Hi all,
I'm looking for the NX API matching the JtkProperty API ?
I've made tests, adding a custom attributes in NX UI, but the custom attribute is not exported to the JT file.
Can you give me a hint please ?
Thanks.
Re: NX API matching the JtkProperty API ?
If I may rephrase the question, when exporting a JT file from NX the JtCreator writes JtkProprety like
JT_PMI_CONTENT_HINT
CAD Source::
CAD_PARTNAME::
JT_PROP_ORIGINATING_BREPTYPE
and others JtkProprety items to the JT file.
The question is: how can I add my own properties/attribute/thing so that it appears in the resulting JT file ?
I don't found any workaround (except horrible hacks)...
Anyone can help please ?
