NX Advanced Simulation : How to get Node Id from a mesh point?
In FEMPart,first I have a mesh model with nodes, elements. I create a mesh point and then update the model, and now I have a new mesh model with new nodes and elements. How can I get the node ID exactly on the mesh point I create?
Re: NX Advanced Simulation : How to get Node Id from a mesh point?
Hi Xiang,
this question has been discussed and solved here:
http://community.plm.automation.siemens.com/t5/NX-Programming-Customization/How-to-get-the-FENode-as...
regards,
MGeyer
