NX Block UI Sytler - String --> Autocomplete
Hello.
I've found  in  "NX Block UI Sytler"-item "String" the "PresentationStyle Autocomplete" as you can see at the picture below. It seems to be working.
Now want to change the values of this item an insert my own.
How can I do it?
Thanks.
Alex
Re: NX Block UI Sytler - String --> Autocomplete
Esteemed Contributor
Do you want to select from a list of your own items, then you would use an enumeration block, which can be displayed as a combo box or drop-down list.
A string block is just for entering strings and it offers NX KF functions to be entered too as with all the regular input blocks (integer, real, string, etc.)
It will be over thousend items. This seems not be useful.
Ok, I thought I could handle this with Autocomplete.
Is there something similar with autocomplete? (like windows search, google)
Alex
A combo box has usually auto complete build in, so this should work.
