NX File->New DIalog Customization
Builder
Builder
One clarification required. Can i customize the NX File->New dialog by adding some feilds/list ?
Like adding a Textbox/ListBox/Combobox in the UI.
Is it possible? If yes where can i find some references to get started?
Santosh
Re: NX File->New DIalog Customization
You can't change the dialog, you will have to build your own from scratch.
You can add new tabs by creating/adding your own .pax files, but as Stefan says, the overall design of the dialog is fixed.
