NX Icon/Image files
drawingimages.pngAnnotation Editor Symbols
Is it possible to download the above icon/image files from GTAC. This will be helpful to design my custom application
Thanks & Regards
Balakrishnan M
7 REPLIES 7
Re: NX Icon/Image files
In NX, you don't need the files, just the names.
For the lower box, they are:
straightness
flatness
circularity
cylindricity
tophalfcircle
tophalfmoon
angularity
perpendicularity
parallelism
position
concentricity
symmetry
runout_circular
runout_total
quantity_drafting
phi
phi_s
circle_m
circle_l
circle_s
circle_u
circle_p
circle_f
circle_t
independency
continuous_feature
statistical_tol
circle_e
a_uc_box
b_uc_box
c_uc_box
d_uc_box
e_uc_box
f_uc_box
Where do you see the upper set in NX?
Mark Rief
Retired Siemens
Thanks for your response
I got these symbols in annotation editor. Find the following image for your reference
Thanks & Regards
Balakrishnan M
Here you go :*)
countersink
counterbore
spot_face
depth
conicaltaper
slope
square
plusminus_black
degree
arclength_sym
paren_left
paren_right
between
fitfunction
phi
phi_s
safetycompliance
quantity_drafting
centerlinesymbol
ohm
circularity
triangle_isosceles
right_taper_symbol
Mark Rief
Retired Siemens
please share the name of the above symbols
Thanks & Regards
Balakrishnan M
What is the command path to get to the dialog where you see them?
Mark Rief
Retired Siemens
These icons present in Annotation Editior - >Category GD&T
Thanks & Regards
Balakrishnan M
The names should be...
frame_single
frame_composite
frame_next
seperator_vertical
best regards
Markus
