NX Manager drawing name after file new
is there a way to change the separator for the UGMASTER dataset filename when creating a drawing from 3D part (master model)
I see only "." and "-" in customerstandards options, is there any way to bring in custom separator?  Ineed "_" like in native
TC Integration File New options;
in native there is one more that I need
need to get both dataset with same naming
Re: NX Manager drawing name after file new
Problem solved with PLM Easy Preference: TCPB_Datasetnames
