NX Open BockStyler SpecifyCsys
Experts,
I have created a dialog that have the following blocks:
- SpecifyPoint
- SpecifyVector
- SpecifyCsys
When the user lauch the dialog, i want to show the stored point, the stored vector and the stored csys. For the point and vector, I have the method SetPoint and SetVector, so everything go fine.
The problem is that I dont have such methods for SpecifyCsys block. I know that I can use the function SetSelectedObject, but I need to create a new CSYS for that, which I want to avoid. I need method like SetPoint(Point3d& origin) and SetVector(Vector3d& x, Vector3d& y)
Why such methods are not available for SpecifyCsys block ? Is there a workaround ?
Please note that in my data, the stored CSYS data have been obtained by using the GetSelectedObjects method from the SpecifyCsys block.
Thanks in advance
