NX Open Java not working on OS X Yosemite.
Master
Master
Any one use NX Open Java on OS X Yosemite?
A message to install Java 6 will appear. Thats it.
I have insatlled Java 7 and 8.
Re: NX Open Java not working on OS X Yosemite.
Marcel,
Good morning.  What version of NX are you using?  The certification tables show that NX10 is the first release to be supported on Yosemite (10.10).  NX10 uses Java 1.8 on Mac OS X, so if you are getting a message about Java 6, I would guess you might be using an older version of NX.
Steve
Master
Master
We use (try to) the latest NX10 and the latest OSX Yosemite
Java is 1.8. all is in the certification range.
In that case, please log an incident report with GTAC so that we can perform a thorough investigation.  Thanks!
Master
Master
PR 7328657 is open since 19-mar-2015 and still no solution.Smiley Mad
Please contact the GTAC Coordinator who submitted the PR for you.  He or she can contact the development team who has the PR to see if there is any new information about the issue.
Thanks!
Master
Master
We have done all possible things even escalating the PR has no effect.
Talk to a wall is more slimple then getting a answer.
I guess after a year or so we hear "NX Open Java is no longer suportet on OS X" as answer.Robot Frustrated
