NX Open using C# through Visual Studio
Dear all,
I am new to NX Open, can any one guide me how to start NX Open programming using C# through Visual Studio.
Thanks in advance.
Yunus
6 REPLIES 6
Re: NX Open using C# through Visual Studio
Did you read this post. What additional information do you need?
山田
yamada
(view in My Videos)
Refer attached video Nx Getting Started with C#.
Manikandan
Dear Yamada,
Thanks for sharing the information.
Yunus M
Dear Manikandan,
Thanks for your reply. I shall let you know if any information is required.
Yunus M
Dear Yamada,
This post contains code explaination using Visual Basic.
Are there any material for C#?
Yunus M
The “Getting Started” guides only discuss VB. There are no analogous documents for C#. However, the only difference between VB and C# is the language syntax; everything else is the same. So, if you know how to write C# code, it should be fairly easy to understand how to use C# with NX.
The .NET Reference guides cover both VB and C#.
山田
yamada
