NX User Exits Java
I wrote serveral nxopen programs ,and I want to write a update framework to update all the programs automatically.How can I make the updata program start when nx startup?
The MenuBarJavaApp sample isn't work.And the siemens document mention User exits may help this situation,but there is no sample code in java .I write a java class with entry function :
public static void startup (String [] args)throws NXException, java.rmi.RemoteException
but turn out with this exception:
Re: NX User Exits Java
I set the system environment name USER_STARTUP point to the java appliction is work.
Startup entrypoint don't support .class file, but support .jar file.
