NX10 licensing problem with Java
I'm using NX10 and Windows 7 and is trying to install the license server. There is no problem to install NX10, but when I try to install the license server, I get the following fault:
Java Virtual Machine Launcher, Error: opening registry key 'Software\JavaSoft\Java Runtime Environment'
Java Virtual Machine Launcher, Error: could not find java.dll
Java Virtual Machine Launcher, Error: Could not find Java SE Runtime Environment
I've tried both with the GUI and with the cmd (version 6.4.2 and 7.2.0 of the SPLMLicenseServer-program). I have the latest Java (8 Update 60) installed.
Any idea what is missing? I've tried uninstall and reinstall Java, NX and most other things, but nothing helps. Everything else works fine except installing the license server.
Re: NX10 licensing problem with Java
Try with the suggestions linked here :
http://community.plm.automation.siemens.com/t5/NX-Programming-Customization/NX10-instalation-license...
Thank you...
Using NX 11 / RuleDesigner PDM
I had read and tried that before without success, but missed the reply with downgrading Java to 8u51. When I did that, the install worked fine. So the problem seems to be Java 8u60.
Thank you very much Cubalibre00!
