NX11 replacements API for ufunc attribute routines
The following ufunc routines are completly removed in NX11,
uc2703
uc5091
uc5096
uc5094
uc5090
uc5126
uc5122
uc5118
uc5114
uc5105
uc5104
does anyone know how to get the NX programming documentation that contains the above routines, this is to see the purpose and the argument details of these API, so that I can look for the replacements in NX11?
I found the old NX documentation at this link:  https://support.industrysoftware.automation.siemens.com/general/nx.shtml.  However, it appears that they removed the programming documentation for releases prior to NX7.5
Thanks in advance
Re: NX11 replacements API for ufunc attribute routines
Siemens Genius Siemens Genius
Siemens Genius
From what I gather, these deleted routines were VERY old, not necessarily replaced by new functionality in NX 11.
For example, I went back a dozen years to old NX 2 Open Help and found the following which documents replacement routines for some of the attribute read value routines in your list (this is all the documentation I could find on the subject):
Note that before the NX7.5 release, the NX Help was not posted on the GTAC site due to licensing restrictions, only the What's New Guide and Release Notes which came with the software were posted. So this material wasn't removed, it was never available
uf_attr.h
Legacy Routines
Replacement Routines
Wrapper
uf/uc5104 read string attribute title
UF_ATTR_read_value
Yes
uf/uc5105 read string attribute value
UF_ATTR_read_value
Yes
uf/uc5114 read integer attribute title and value
UF_ATTR_read_value
Yes
uf/uc5118 read floating point attribute
UF_ATTR_read_value
Yes
uf/uc5122 read null attribute's title
UF_ATTR_read_value
Yes
uf/uc5126 read date and time attributes
UF_ATTR_read_value
Yes
NX Design Apps Documentation & Courseware Manager
Siemens Genius
Apparently this information is still available in the NX 11 Open C Programmer's Guide:
https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_api/#uid:xid879421
Thanks Gregg, your information's are really helpfull.
