NX110custom mapped drive permission issue
I have a window 10 computer with NX loaded, and the NX11custom files are on a mapped network drive.  I'm getting the following during NX startup.  I know it's related to the navigator settings trying to be written to the computers registry.  What do I need to do, to give it permission?
Unable to import registry keys from \\hanger18\UG Files\NX110custom\NX110library\_NXCustom_Management\NX_ONAV_COLS_GEOM.reg
Please contact your IT department for possible restrictions on importing of registry keys
Press any key to continue . . .
-Dave
NX 11 | Teamcenter 11 | Windows 8.1
Re: NX110custom mapped drive permission issue
a bit of testing, and this is only if i use a shortcut to the .bat file, if I browse to the .bat file via windows explorer, it launches without issue.
-Dave
Solved.  The shortcut I was using is the one that came in the NX11custom zip file.  Creating a new one took care of it.
-Dave
