NXOpen C++ FENode.GetElements API is not working as expected
NXopen::CAE::FENode->GetElements() is not returning the proper vector. Tried with different node in FE mesh created in NX Adv Sim Please help or suggest any alternate (UFUNC API ) to find attached elements to a node.
4 REPLIES 4
Re: NXOpen C++ FENode.GetElements API is not working as expected
If you are experiencing a problem with a method in the API, please file a report with GTAC so that it can be addressed.
https://support.industrysoftware.automation.siemens.com/
An alternative method to get elements related to a node is to use:
NXOpen.CAE.SmartSelectionManager.CreateRelatedElemMethod(NXOpen.CAE.FENode()) As NXOpen.CAE.RelatedElemMethod
Hi Jim,
Thanks for replying. I tried your suggestion but same result (see attached)
About my model:
It is a independent LSDyna Solid (Hex) mesh - No association with geometry. Can that be a issue?
Rajat
Advanced Engineer
Rolls Royce India
At this point it would be best to contact GTAC and/or post your specific code and fem/sim files that you are running it in.
Sure,
I'll ask this in GTAC.
Rajat Gupta
The data contained in, or attached to, this e-mail, may contain confidential information. If you have received it in error you should notify the sender immediately by reply e-mail, delete the message from your system and contact +44 (0) 3301235850 (Security Operations Centre) if you need assistance. Please do not copy it for any purpose, or disclose its contents to any other person.
An e-mail response to this address may be subject to interception or monitoring for operational reasons or for lawful business practices.
(c) 2017 Rolls-Royce plc
Registered office: 62 Buckingham Gate, London SW1E 6AT Company number: 1003142. Registered in England.
