NXOpen C++: how to get the attribute with multiple values
Hi, everyone. Recently I am undergoing a project to get the attribute of Routing:: Stock object, for normal attributes, I can reach them by Stocks->GetStockData()->GetStringCharacteristic (const char *name). However, for  attribute with multiple values("test" attribute as shown in the picture), how can I get each value of them?Capture1.PNG
 I also tried GetStringUserAttribute (const NXString &title, int index), but it doesn't work.
Re: NXOpen C++: how to get the attribute with multiple values
Esteemed Contributor
From the NXOpen.Part object you use the method GetUserAttributeAsString(), which is the newly introduced function in NX 8.
I met a very strange thing. The picture 1 is the a defaut attribute which has already existed, the picture 2 is the same attribute modified by myself. The picture 3 is an attribute defined by myself. And I use the following code to read these attribute, the result really confused me. Can find what's the problem?
It shows that it can get the attribute for default attributes, but it returns the same value for multiple value(It seems what I modified doesn't work). And it just can't find the attribute defined by myself.
What does the syslog tell you about the exception of the last example?
