NXOpen How to select a curve in a sketch
Siemens Creator
I would like to select a curve (an arc to find the diameter). This curve for this part, is in a sketch.
I do not find how to do.
I miss understanding something between UF and cpp function:
  • If I use 'UF_OBJ_ask_type_and_subtype' I find type 5 (= UF_circle_type).
OK, fine.
  • If I use FeatureType() I find "SKETCH".
I can cast my feature in sketch and do many things (list curves...) but not to have The curve I select.
Thank in advanced for your help.
Jonathan
Enclosed a simple part and simplified code (it compile and is usable as dll)
Re: NXOpen How to select a curve in a sketch
Honored Contributor
Honored Contributor
My code is in VB as opposed to C++, but I think it conveys the idea.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Dim theArc As Arc
        If SelectArc(theArc) = Selection.Response.Cancel Then
            Return
        End If
        lw.WriteLine("Diameter: " & theArc.Radius * 2)
        lw.Close()
    End Sub
    Function SelectArc(ByRef selArc As Arc) As Selection.Response
        Dim theUI As UI = UI.GetUI
        Dim title As String = "Select an Arc"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim cursor As Point3d
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
        Dim selectionMask_array(0) As Selection.MaskTriple
        Dim prompt As String = "Select Arc"
        Dim selObj As TaggedObject
        With selectionMask_array(0)
            .Type = UFConstants.UF_circle_type
            .Subtype = 0
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _
         title, scope, selAction, _
         includeFeatures, keepHighlighted, selectionMask_array, _
         selObj, cursor)
        If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
            selArc = Utilities.NXObjectManager.Get(selObj.Tag)
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
