NXOpen Remoting in Java is not working
Hello All,
I am trying to do remoting using Java. I am making use of sample applications provided in UG installed directory. I am able to run the   NXRemoteServerImpl.class and I am getting the message in Listing window. The message says Binding Session Session bound.  But while executing the client  i am getting an error saying Exception in thread "main" java.lang.NoClassDefFoundError: nxopen/Session
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2701)
at java.lang.Class.privateGetPublicMethods(Class.java:2902).
Can somebody shed some light on this issue.
Thanks in advance.
Raghavan
Raghav
