NXcustom env directory path with spaces?
I'm setting some env variables, which are directory paths, to save g-code.  In some cases there are folder names with spaces in them, and I'm not sure how to deal with them?   quotes around the path? or do I need to convince them the spaces need to be underscores?
Example:
Y:\Manufacture Parts Catalog\Machinist WIP\A-Lathe
-Dave
NX 11 | Teamcenter 11 | Windows 8.1
Re: NXcustom env directory path with spaces?
It`s always better to avoid space and add underscores.
But you can also put your path between quotes "" and it will work, but generally, I avoid using spaces.
