Need help: Getting"Error found during reload" in Check Mate Author Tests
I 'm trying to create a custom checker in NX9 and wrote the following dfa file(attached with this post) using the "Author Tests->Create/Edit check" dialog.
After Coding this custom checker, I check the "Load after save option in the dialog and click the "Save Checker As" Button.
The dfa file stores in the specified location but I get a popup with the following message "Error found during reload".
I checked the NX log file and donot get any furhter information (or clue)on how to debug further.
Any help would be appreciated.
