Need help for NXOpen\Block Styler
Hello! I'm just starting to learn NXOpen and I need help. I use Block Styler to create a dialog. I have a face selection block. Can I get the coordinates of the borders of the selected area?
4 REPLIES 4
Re: Need help for NXOpen\Block Styler
If I understand correctly, you need the coordinates of the face border ?
If yes, from the face, get the edges, and from each edge, get the vertices coordinates
Elias.
Yes, its correct)
But how do i get the edges? Do I need to select them separately? Or can I get them from the selected face? And how can i get the vertex coordinates? Sorry for so many questions, I'm really just learning)
From face, use GetEdges method:   Edge[] edges = face.GetEdges()
For each edge, use GetVertices methods:  GetVertices(out Point3d vertex1, out Point3d vertex2).
Elias.
Thanks you! This what I need.
