Need to extract all the `Model Views' name except standard views in desending order
Hello
In Nx 11 PMI in Part Navigator i need to extract all the `Model Views' name except standard views in desending order.
Currently manually i am doing this by
(1) Clicking on `Name' in `Part Navigator' for descending order i.e., black filled arrow should be down,
(2) From top to bottom manually by selecting the view individually and pressing `F2' Rename copying to notepad except standard views and except symbol "" (Example : "MAIN_VIEW" should be copied to MAIN_VIEW without "").
Is there any option for this requirement ?
Note :
(a) All the 8 following standard views anmes should not be taken "Trimetric", "Top", "Right", "Left", "Isometric", "Front", "Bottom", "Back".
(b) Camera views no need to consider for copy.
thanks in advance
Sekar
Re: Need to extract all the `Model Views' name except standard views in desending order
https://www.eng-tips.com/viewthread.cfm?qid=308809
From Google i foudn a journal (attached in notepad) from above link.
This journal is shown the view names one by one by information box.
But i need all the view names except standard model view names in notepad sorted desending.
thanks in advance
Sekar
@Sekars , Export to spreadsheet and edit it as you want.
The journal you have pointed was posted by @cowski1. He can enlighten us further.
Hi @Sekars ,
Below code gives the list of manually created views but I couldn't sort in descending order. Maybe you can just copy them in excel and sort them.
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim lw As ListingWindow = theSession.ListingWindow
Dim displayPart As Part = theSession.Parts.Display
'Dim list As New List(Of String)
Dim ViewNames() As String
Dim views As ModelingViewCollection
views = workPart.ModelingViews
lw.open()
    For Each vw as ModelingView in views
    'For Each vw as ModelingView in views.OrderByDescending(Function(v) v.Name)
    'For Each vw as ModelingView in views.Cast(Of ModelingView)().OrderByDescending(Function(v) v.Name)
       ' lw.writeline(temp.Name.ToString)
            Select Case vw.Name.ToString
                Case "Back"
                Case "Bottom"
                Case "Front"
                Case "Isometric"
                Case "Left"
                Case "Right"
                Case "Top"
                Case "Trimetric"
                Case Else
                    lw.writeline(vw.Name) ''' Print user added views
            End Select
    Next
lw.close()
End Sub
End Module
Samadhan
Try this:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Module Module2
    Sub Main()
        lw.Open()
        Dim userModelViews As New List(Of ModelingView)
        Dim cannedViews As Array
        cannedViews = System.Enum.GetNames(GetType(NXOpen.View.Canned))
        'iterate through the view collection, adding each view name to the string array
        For Each tempModelView As ModelingView In theSession.Parts.Work.ModelingViews
            Dim skip As Boolean = False
            For Each cannedView As String In cannedViews
                If tempModelView.Name = cannedView Then
                    skip = True
                End If
            Next
            If Not skip Then
                userModelViews.Add(tempModelView)
            End If
        Next
        'sort the list alphabetically
        userModelViews.Sort(AddressOf CompareViewNames)
        'reverse the list
        userModelViews.Reverse()
        For Each temp As ModelingView In userModelViews
            lw.WriteLine(temp.Name)
        Next
    End Sub
    Private Function CompareViewNames(ByVal x As ModelingView, ByVal y As ModelingView) As Integer
        'case-insensitive sort
        Dim myStringComp As StringComparer = StringComparer.CurrentCultureIgnoreCase
        'for a case-sensitive sort (A-Z then a-z), change the above option to:
        'Dim myStringComp As StringComparer = StringComparer.CurrentCulture
        Return myStringComp.Compare(x.Name, y.Name)
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Hello cowski1 and Samadhan
Thanks for your journals
Both cowski1 and Samadhan Journals working well, i will cowski1 since have the sort to descending option also.
Thanks once again for both of you
Sekar
