Not able to get faceted faces of triangulated mesh (.STL) file
I have import a .stl file in NX 11.
In my application ,i retrvieve that facetedBody from part.
I want faceted faces from this facetedBody . So I have implemented following code.
NXOpen.Part workPart = Session.GetSession().Parts.Work;
NXOpen.Facet.FacetedBodyCollection facetedBodies = workPart.FacetedBodies;
NXOpen.Facet.FacetedBody[] facetedBodiesInPart = facetedBodies.ToArray();
for (int i = 0; i < facetedBodiesInPart.Length; i++)
NXOpen.Facet.FacetedBody facetedBody = facetedBodiesInPart[i];
Body body = facetedBody.AssociatedBody;
if(body == null)
int numfaces = facetedBody.NumberOfFaces;
try
//I got exception here.
NXOpen.Facet.FacetedEdge[] edges = facetedBody.GetEdges();
NXOpen.Facet.FacetedFace[] faces = facetedBody.GetFaces();
catch (NXOpen.NXException ex)
UI.GetUI().NXMessageBox.Show("Caught exception in Main", NXMessageBox.DialogType.Error, ex.Message);
try
double vol = facetedBody.Volume;
double area = facetedBody.SurfaceArea;
But it gives exception for geting faces and edges.
Can you please tell us how to get faceted faces from faceted body?
Re: Not able to get faceted faces of triangulated mesh (.STL) file
You might find this discussion useful.
山田
yamada
