Obtaining DatumPlane from WaveDatum
Hello everyone!
I have a code that works well for me
foreach (Feature feature in workPart.Features)
    if (feature.FeatureType.Equals("DATUM_PLANE"))
        DatumPlaneFeature datumPlaneFeature = (DatumPlaneFeature)feature;
        DatumPlane datumPlane = datumPlaneFeature.DatumPlane;
But now I need to work with linked Datum planes and therefore feature type is WaveDatum. It does not work anymore - cannot convert from WaveDatum to DatumPlaneFeature. I'm quite stuck here. How do I obtain DatumPlane from WaveDatum???
Re: Obtaining DatumPlane from WaveDatum
You can use the wave datum's .GetEntities method to get the datum plane.
It has already dawned on me after I posted this quiestion. Thanks anyway!
