Obtaining drafting view scale
Hello everyone!
How can I obtain the scale of the drawing view? I tried the .Scale property of the DraftingView object, but it returns different kind of scale, more like zoom. I can read the VWSCALE attribute and get the scale from there, but maybe it is still possible directly from the DraftingView object?
Re: Obtaining drafting view scale
Have you tried recording a journal of setting the view scale for a driawing view?
That should point you to the correct code to read the scale
I did, but I could not utilize that code for my purpose. It looks like a code to set a scale, not to read it. Am I wrong?
{drafting view}.Style.General.Scale
You can query or set the scale with this property.
Thank you!
