Obtaining master part of a drawing
Hello everyone!
Is there a dedicated way to obtain master part of a drawing? Or shall I simply obtain assembly component in a usual way?
Re: Obtaining master part of a drawing
There is no "dedicated" way that I know of. A "master" part of a drawing is a component just like any other.
I asked because if you create non-master drawing with the DB_DWG_TEMPLATE attributes, which hoover up attributed from the master part, it seems to create some sort of a relation. If other parts are later added to the same drawing file alongside the master part, the attributes still point towards the original master part. So at this level at least an original master part is recognised apart from the rest of the components. But not quite clear how.
