Obtaining section line end segments
Hello everyone!
How can I obtain end segments of a section line on a drawing? Currently I can't figure out how to obtain either section line or section line segments...
Re: Obtaining section line end segments
If you have a reference to a section view, you can use .AskSxlineOfSxview to get the tag of the section line. You can ask the type of the section line with .AskSxlineType and once you know the type, you can use
  • .AskSimpleSxline
  • .AskSteppedSxline
  • .AskRevolvedSxline
  • .AskHalfSxline
  • .AskUnfoldedSxline
  • etc
to get the segments of the section line.
Note: my comments apply to NX 9. I know that NX 10 provides a new way to define the section line; I don't know what effect that has on the return value of the functions mentioned above (if any).
Thank you! I will have a try asap.
