Open PDF in a ribbon toolbar with the command ACTION
Does anyone know how to open PDF file with the ACTION command in ribbon toolbar NX10?
On NX10 I can´t make it work
Many thanks,
Best regards,
Re: Open PDF in a ribbon toolbar with the command ACTION
Esteemed Contributor
You can specify a windows command script (BAT or CMD) as action.
With the following content
start "" "{full path to PDF}"
The NX menuscript documentation contains the various possible executables for the ACTION keyword.
This works in your NX?
In my case, ACTION start "" "C:\HELP.pdf" doesn´t work...
In previus version like NX8.5 with the command ACTIONS works fine but not now...
Many thanks,
Best regards,
I think you didn't read my first sentence carefully.
Content of the MEN file:
ACTION "C:\OpenPDF.cmd"
Content of the CMD file:
At Menuscript help for NXOpen C it says that you can run system commands (EXE, BAT or CMD).
START is a shell command, so you need to run a Windows script (BAT or CMD) to use it.
Another thing to look at...
I was having problems defining a button in an RTB to directly access an OS command.
However, if I add a button to the *menu* using menuscript, then I can use that menu button's name in the RTB file.
I always create a menu file, since you have much more options than with the tool bar files.
In addition you can make a menu entry available only in one specific application easily, where this is nearly impossible for a tool bar entry.
If you use the ...\Application\profiles\UG_APP_*\... folder structure, you can have RTBs (and I assume other things) be application specific.
Yes, the problem was in the *.tbr file with the Statement ACTION. In the *.men file with ACTIONS works fine.
Many thanks to Ken_A and Stefan_Pendl, without your help, I wouldnt have done it Smiley Happy
Best regards,
