Open and edit UDF - vb.net
I would like to edit a UDF. It is a function implemented by our costumer as .dll in the NX functions.
In this feature, when created, there are some values about the part which need to be updated sometimes.
I would like to perform this update automatically.
The feature in the Part Navigator is called "Material Feature".
With this API I am able to get the material feature.
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&dt=nx-api&ai=NXOpen&le=...
Now I need to open it and perform an update simply by pressing "OK" .
Thats the Feature when opened manually.
Looking forward to your responses.
Mathieu
