Opening a part file from batch
Innovator
Innovator
Is there a way to start a session of NX from a batch  file and have it immediately open up a part file as soon as the session is open?
Re: Opening a part file from batch
ugraf.exe -retrieve (file) should do that.
I have to find it in the docs to see what the exact syntax is.
Innovator
Innovator
Okay yeah not sure how exactly to do that.
Syntax would be great Smiley Happy
"ugraf.exe" is the command to start the NX interactive process.  You can use a command-line argument to make it open a part immediately, like this:
ugraf.exe -retrieveSmiley Very Happy:\_NX9\_Parts\ToyCar\toycar_assy.prt
This is documented under Fundamentals -> Launching NX -> Start NX on Windows Platform -> Command Line Startup Switches for Windows.
