Opening part files
Hey,
i have a problem in my application opening a part file.
Following code:
public void loadPrt(String PathofSession,String SessionName)
           if (theSession.Parts.ToArray().Length != 0)       //closes an opened part
               theSession.Parts.Work.Close(NXOpen.BasePart.CloseWholeTree.False, NXOpen.BasePart.CloseModified.CloseModified, null);
           PartLoadStatus partloadstatus;
           theSession.Parts.Open(PathofSession + SessionName, out partloadstatus);    //open new part
PathofSession is "c:\\NXToolPath\\" and SessionName is "Master.prt"
Unfortunately i get an exception as follows:
"An unhandled exception of type 'System.AccessViolationException' occurred in NXOpen.dll" at Open() Method - saying that tried to read/write in protected memory.
I am using .netframework 4.0 and Visual Studio 2012
Does anybody have had the same issue or an idea to solve it?
I tried different files and filepaths, doesn't help.
Thanks in advance!
Re: Opening part files
I've not seen this particular error, but you might get more information if you add some error handling; perhaps something like (VB used below):
        Dim fileName As String
        Try
            fileName = IO.Path.Combine(PathOfSession, SessionName)
            lw.WriteLine("filename: " & fileName)
        Catch ex As Exception
            lw.WriteLine("error: " & ex.Message)
            'other error handling code...
        End Try
        If IO.File.Exists(fileName) Then
            Try
                Dim partLoadStatus1 As PartLoadStatus
                theSession.Parts.Open(fileName, partLoadStatus1)
                lw.WriteLine("error while opening file: " & ex.Message)
                'also check the value of 'partLoadStatus1'
            End Try
        Else
            'report file not found
            lw.WriteLine("file not found: '" & fileName & "'")
        End If
Also check the release notes of your NX version, it will list which .net framework to use when programming NX.
Error will occur If session doesn't have workpart and code trying to access the workPart property.
Add this code inside the if condition.
try
Part part1 = (Part)theSession.Parts.FindObject(sessionName);
    part1.Close(NXOpen.BasePart.CloseWholeTree.True, NXOpen.BasePart.CloseModified.UseResponses, null);
catch
Selvaraj Chellamuthu
NX Automation Engineer
NX 9.0 | Teamceneter 10.1
I have tried both, but still the same error. Smiley Sad
@cowski1: Unfortunately i don't get any further information via the try-catch operation. all i found out via exception details is that openbasedisplay() takes 3 arguments (NXOpen.PartCollection.JA_PART_open_base_display(IntPtr filename, Tag& part, IntPtr& loadStatus) ) ??
Where exactly in the release info do i find the .net framework?
@SelvarajC: There is no part opened so i won't get the workpart from theSession. Is there a way to directly access the workpart from fileName?
thanks
ingfu.
// Way to access the Work part
Part workPart = theSession,Parts.Work;
if(workPart == null)
theSession.ListingWindow.WriteLine("No work part found");
Above code shows the way of collecting the work part.
if "workPart" variable is null then session does not have any work part.
Do you want to collect a part using specified name?
theSession.Parts.work = null
beceause there is no part loaded yet.
I want to load components from the fileName (c:\\NXToolPath\\Master.prt)
Do you want to load as work part?
            theUI = UI.GetUI();
            theUfSession = UFSession.GetUFSession();
            workPart = theSession.Parts.Work;
            displayPart = theSession.Parts.Display;
This would be the next code.
Yes i want to load workpart.
// Try this piece of code.
NXOpen.Session theSession = NXOpen.Session.GetSession(); NXOpen.Part[] parts = theSession.Parts.ToArray(); string filePath = @"c:\\NXToolPath\\Master.prt"; NXOpen.Part expectedPart = null;
// Collect the part file if already opened foreach (var item in parts) { if (System.IO.Path.GetFileNameWithoutExtension(item.FullPath.ToUpperInvariant()) == System.IO.Path.GetFileNameWithoutExtension(filePath.ToUpperInvariant())) { expectedPart = item; } } if (expectedPart == null) { NXOpen.PartLoadStatus loadStatus; theSession.Parts.OpenBaseDisplay(filePath, out loadStatus); loadStatus.Dispose(); } else { NXOpen.PartLoadStatus loadStatus; theSession.Parts.SetDisplay(expectedPart, false, true, out loadStatus); loadStatus.Dispose(); }
Thank you for the quick answers.
UNfortunately the given code produces same error as before in
I wonder if this error has something to do with the x64 application and the x86- NXOpen.dll
