Operation Work Instruction
Hello
I tried to make a custom work instruction. I found a good description in the NX10 Documentation. But at the end i fail...  Does anybody did a custom work instruction?
I work with NX 10.0.3.5 MP08
Here are the pictures from the doc wich i used to make the custom template:
I think my error is at the end by saving and publish the file...
If i start NX there ist this error:
If i turn off the Preview the error pops up if i want to pubish the work instruction.
I dont understand exactly the log file...
>>>> Error code  1770010 caught in file "o:\ugnx1003\ip5\src\camsmom\no\ind\mom_tcl_tclex.c" at line number 2104
Fehlercode 1770010: MOM_TCL: Can not execute command.; TCL error couldn't change working directory to "C:\PLM\nx10_reinach\MACH\custom\owi\owi_custom_template_tool_list_by_name_files": no such file or directory returned when executing command MOM_End_Part_Documentation, errorInfo = couldn't change working directory to "C:\PLM\nx10_reinach\MACH\custom\owi\owi_custom_template_tool_list_by_name_files": no such file or directory
    while executing
"cd "[file rootname $ex_doc_template_file]_files""
    (proced
*** EXCEPTION: Error code  1770010 in line 933 of o:\ugnx1003\ip5\src\camsmom\no\ind\mom_tcl_definitions.c at Thu Mar 30 21:57:53 2017 Mitteleuropäische Sommerzeit
+++ TCL error Fehlercode 1770010: MOM_TCL: Can not execute command.; TCL error couldn't change working directory to "C:\PLM\nx10_reinach\MACH\custom\owi\owi_custom_template_tool_list_by_name_files": no such file or directory returned when executing command MOM_End_Part_Documentation, errorInfo = couldn't change working directory to "C:\PLM\nx10_reinach\MACH\custom\owi\owi_custom_template_tool_list_by_name_files": no such file or directory
    while executing
    (proced returned when executing command MOM_do_template_file "C:\\PLM\\nx10_reinach\\MACH\\custom\\owi\\owi_excel.tpl", errorInfo = Fehlercode 1770010: MOM_TCL: Can not execute command.; TCL error couldn't change working directory to "C:\PLM\nx10_reinach\MACH\custom\owi\owi_custom_template_tool_list_by_name_files": no such file or directory returned when executing command MOM_End_Part_Documentation, errorInfo = couldn't change working directory to "C:\PLM\nx10_reinach\MACH\custom\
I hope sombody can help me...
Thank you very much for every information you got for me.
Best regards
Production: {NX 10.0.3.5 MP18}
Testing: {NX 12.0.2.9 MP01}
Re: Operation Work Instruction
Dies the directory C:\PLM\nx10_reinach\MACH\custom\owi\owi_custom_template_tool_list_by_name_files exist?
Mark Rief
Retired Siemens
You are right
This folder is not existing...
I thought that the folder, which created itself is enough... i created an empty folder with the correct name and it works properly
Thank you very much for your help
German Micro-Schrott Office creates German folder names, but NX expects English folder names.
With the Excel-Garbage you will always have to rename the "_Dateien" folder to "_files" to make things work.
Thats true.
I did not expect excel would change the folder-ending in case of the languagesettings...
I hope this posts helps other users with the same problem.
Best regards from Switzerland
