PCB Exchange: Export ECAD model programmatically using NX Open API?
I'm open Export ECAD model dialog and setting
Board File
Library File
Filter
-> OK to export
Question:
How can I get related setting and call export function programmatically using NX Open API?
Re: PCB Exchange: Export ECAD model programmatically using NX Open API?
Start recording a journal prior to following the above process interactively.
Sorry if i don't describe clear. I have recorded the journal but it just create a BlockDialog and set information to block item. My question is how can i get the setting information and call export by using NX Open API.
EX:
using NXOpen.Session, NXOpen.UI, NXOpen.Part to get setting from Export Ecad Model dialog. After that call method to export ECAD model.
