PLM License server Issue
Hi
I'm new to this community. I have a problem regarding the installation of NX 11.0. When I try launch lmtools.exe and try to start the server I get this error: "Server Start Failed. The Server May Already Be Running!!". Attempting a force stop and then restarting did not help. I think the problem starts from here: There is this service called "Siemens PLM License Server" that when I even try to start it manually gives an error. "Unable to start service. The operation could not be completed. The dependency service or group failed to start."
I installed Java and updated to the latest version.
Kind Regards
Re: PLM License server Issue
Same issue I faces before for NX 10 though. Downgrading Java and reinstalling everything helped.
Thanks for your reply
To what version should I downgrade?
Java is only used by the installer, the license server is not using Java at all.
Make sure to use the latest license server release available at https://download.industrysoftware.automation.siemens.com/LicenseServerInstall.PNGLicense Server Download
