Part Family Update
I am attempting to replicate the Assembly Part Family Update functionality (Assemblies -> Components -> Part Family Update) through VB.Net and I have found the the NXOpen.UF.UFAssem.InstanceIntent object in the Visual Studio Object Browser but have yet to find any examples showing how to use it. Does anyone have any suggestions?
Scott
Re: Part Family Update
Honored Contributor
Honored Contributor
What version of NX?
Sorry about that. We are using NX 8.5.3.3
Honored Contributor
Honored Contributor
So, you are looking to update the part family members?
If so, I'm not sure NXOpen.UF.UFAssem.InstanceIntent is what you need. NXOpen.UF.Part.UpdateFamilyInstance seems more appropriate...
If the family members do not exist yet, the .GetPartFamilyManager.EstablishMember method might come in handy.
It seems confusing but the instances are already created and I am replacing one with another in an assembly. The assembly then needs to be updated to reflect the new component. In an NX assembly this would be done by selecting Assemblies -> Components -> Part Family Update but I am wanting to do this programmatically.
Esteemed Contributor
Have you already tried to record a journal from the manual action?
Recording a journal is the easiest way to get the methods involved to do it programmatically.
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.4 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
Yes I tried that first and unfortunately it appears that this function is not recordable. Cat Sad
Just a quick response.
I'm not sure if I got the topic.
You try to update a component wich is a family member and has instance intents to a matching member?
You can use
NXOpen.UF.UFSession.GetUFSession().Assem.EvalInstanceIntent(
 ref Instance,
 false,
 out Status);
 to obtain informations and for an update if you set parameter 2 TRUE.
(see documentation for details)
Attached you will find a static method I use for this.
Unfortunatelly it's commented in german and has a lot of our company specific stuff in it.
But it should give an idea.
Greetings
Herbert Macho
EBNER Industrieofenbau
AUSTRIA
NX10.0.3.5 (TeamCenter10 and Native)
Hi Herbert,
I also need to launch part family update in vb.
I have converted the code to vb, but I was unable to use it because it seems that your are using a specific class Smiley Sad
Could you help me ?
Thanks in advance.
Didier
