Part name from Terminating object
I am searching for vb code or function that will return the part number and name(from assembly navigator) from annotation terminating object (Edge, surface etc).
Thanks in advance
Re: Part name from Terminating object
I'm not too familiar with VB, but you should be able to get the info out of my c++ code.
// Selection any objects
std::vector< NXOpen::TaggedObject * > MyClass::select_any_objects()
	NXString message("Select any objects:");
	NXString title("Select objects");
	Selection::SelectionScope scope = Selection::SelectionScopeUseDefault;
	bool include_features = 0;
	bool keep_highlighted = 0;
	std::vector< NXOpen::TaggedObject * > objectArray;
	// Select any object array
	Selection::Response res = selmgr->SelectTaggedObjects(
			message, title, scope, include_features,
			keep_highlighted, objectArray );
	return objectArray;
// Do something
void MyClass::do_it()
	std::vector< NXOpen::TaggedObject * > any_objs = select_any_objects();
	for (auto item:any_objs)
		NXOpen::NXObject * object = dynamic_cast<NXOpen::NXObject *>(item);
		print(object->OwningComponent()->Name());
First i cast my selected item to a NXObject, then use this function
documentation
This gives you access to this, which this class :
component class
Where you can get the name.
