Plane with a handle that can drag
Hello all,
In CAM -> cavity milling -> cutting layer, we have the following control where we can drag the position of the plane using the arrow handle.
How can we program something like this with NXOpen?
Here is what I tried:
1) first create a plane  workPart.planes.
pl1 = workPart.planes.createplane(origin, norm, updateoption.withinModel)
2) use value from "Linear Dimension" in the UI, create an expression
Expression exp = ... CreateSystemExpression(Dist.toString(), unit)
3) create another plane by using
  • CreatePlane(method, alternate, origin, normal, expression, flip, percent, geometry)
for example, pl2 = workPart.planes.createPlane()
Re: Plane with a handle that can drag
A block-based dialog, can contain blocks called SpecifyPlane and SpecifyOrientation. Both of these display a graphical thingie that the user can then drag around the screen, as in your picture.
To create a block-based dialog, you can either use Block UI Styler and a BlockDialog object, or use a Snap.BlockForm object.
