Plot a specific sized window instead of sheet or Current Display
We currently use NXOpen to scale plot size and line weights as well as add banners and other information to plots, cgms, and pdfs. Recently a change occurred with our roll drawing formats that removed some legacy information. Do to other automation, it was decided that the sheet size would remain the same and the user would have to trim the waisted 100mm blank space from the end. Is it possible to tell the plot, pdf, and cgm creation tools to only plot from 0,0 to x,y instead of plotting sheet? I don't want all of the hard and electric copies to have the extra blank 100mm.
