Problem When Adding UDE Event
Hello there,
I recorded a journal for adding three UDE events in a variable contour operation. See the pics below.
The corresponding UDEs are:
1. Extra Spindle On
2. Spindle Off
3. Set Mode
The recorded journal is attached. In the journal, "surfaceContourBuilder1" was committed twice. I commented out the one on line 570. Then I could run the journal to test, but only UDE 3 was added.
I was wondering if there is anything wrong with the recorded journal.
